[mapserver-dev] Use of XML namespace URIs in MapServer
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Thu Oct 1 13:59:15 EDT 2009
Hi Daniel,
I would leave it as it is. As you say it does not need to point to
anything, it's a URI.
For instance the OpenLayers.Format.GML has it as its default value:
OpenLayers.Format.GML = OpenLayers.Class(OpenLayers.Format.XML, {
     * APIProperty: featureNS
     * {String} Namespace used for feature attributes.  Default is
     *     "http://mapserver.gis.umn.edu/mapserver".
    featureNS: "http://mapserver.gis.umn.edu/mapserver",
I am sure there are more out there ....
Best regards,
Bart
Daniel Morissette wrote:
> Ticket http://trac.osgeo.org/mapserver/ticket/3142 raises an issue
> about the default namespace URI used by MapServer which is currently
> http://mapserver.gis.umn.edu/mapserver and apparently this breaks some
> apps because this URL does not resolve to anything. Docs about XML
> seem to say that the namespace URI does not absolutely have to resolve
> to anything, so we are still waiting to hear from the reporter which
> apps that breaks.
> Regardless, I thought we could simply change the default to
> http://www.mapserver.org/mapserver but Tom wrote that some parsers
> rely on the namespace value and this could cause a backwards
> compatibility issue.
> To avoid bloating the ticket with a long discussion we decided to move
> it here to try to come up with a plan for resolution for the next beta
> (next week).
> Here are a my questions/concerns:
> - I'd be interested to hear more from XML gurus about the real impact
> of changing the default namespace URI from
> http://mapserver.gis.umn.edu/mapserver to
> http://www.mapserver.org/mapserver, even if it's just for consistency
> with our current Internet domain name.
> - While checking docs on namespaces a bit, I saw several examples that
> seem to use a different/unique URL path for different XML schemas.
> Should we not do the same, e.g. http://www.mapserver.org/wms,
> http://www.mapserver.org/xmlmapfile, etc?
> Daniel
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
