[mapserver-dev] Problem with beta2 and SDE access on WMS
benchmarking server
Tamas Szekeres
szekerest at gmail.com
Sun Oct 4 18:17:07 EDT 2009
Jeff,
Could you compile mapserver and the SDE driver in debug mode? If you could
provide a call stack for the error then it would probably help a lot to
track this issue down.
Another option would be to enable the LOG/DEBUG facilities of MapServer and
include further msDebug-s in the code in order to localize the problem.
Best regards,
Tamas
2009/10/4 Jeff McKenna <jmckenna at gatewaygeomatics.com>
> We're hitting an issue with MapServer 5.6.0beta2 in the FOSS4G benchmarking
> exercise[1]:
> - MapServer 5.4.2 with an SDE connection is ok:
> http://64.222.187.168/cgi-bin/mapserv?MAP=/opt/benchmarking/mapserver/sde.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=getmap&layers=areawater-merged-sde,roads-merged-sde,gnis-names-sde&STYLES=&SRS=EPSG:4269&BBOX=-96.980629943844,29.854114257812,-96.79038641357,29.974268066406&WIDTH=950&HEIGHT=600&FORMAT=image/png
> - MapServer 5.6.0beta2 with an SDE connection causes a segmentation fault:
> http://64.222.187.168/cgi-bin/mapserv560beta2?MAP=/opt/benchmarking/mapserver/sde.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=getmap&layers=areawater-merged-sde,roads-merged-sde,gnis-names-sde&STYLES=&SRS=EPSG:4269&BBOX=-96.980629943844,29.854114257812,-96.79038641357,29.974268066406&WIDTH=950&HEIGHT=600&FORMAT=image/png
> - MapServer 5.6.0beta2 connecting to SDE through OGR is ok:
> http://64.222.187.168/cgi-bin/mapserv560beta2?MAP=/opt/benchmarking/mapserver/sde.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=getmap&layers=areawater-merged-sde-ogr,roads-merged-sde-ogr,gnis-names-sde-ogr&STYLES=&SRS=EPSG:4269&BBOX=-96.980629943844,29.854114257812,-96.79038641357,29.974268066406&WIDTH=950&HEIGHT=600&FORMAT=image/png
> We have full access to these benchmarking machines and datasets for this
> competition. Can someone assist us here? We don't see any relevant changes
> in SDE access in MapServer. Thoughts?
> [1] http://wiki.osgeo.org/wiki/Benchmarking_2009
> -jeff
> Jeff McKenna
> FOSS4G Consulting and Training Services
> http://www.gatewaygeomatics.com/
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20091005/4a4fc3d3/attachment.html
