[mapserver-dev] Build error in trunk...
Steve Lime Steve.Lime at dnr.state.mn.us
Fri Oct 16 12:30:37 EDT 2009
Hi all: I'm getting an error when compiling without WFS client support:
mapwfslayer.c: In function ‘msWFSLayerGetShape’:
mapwfslayer.c:918: error: ‘msWFSLayerInfo’ undeclared (first use in this
function)
mapwfslayer.c:918: error: (Each undeclared identifier is reported only
once
mapwfslayer.c:918: error: for each function it appears in.)
mapwfslayer.c:918: error: ‘psInfo’ undeclared (first use in this
function)
mapwfslayer.c:921: error: syntax error before ‘)’ token
mapwfslayer.c: At top level:
mapwfslayer.c:928: error: syntax error before ‘if’
mapwfslayer.c: In function ‘msWFSLayerNextShape’:
mapwfslayer.c:948: error: ‘msWFSLayerInfo’ undeclared (first use in this
function)
mapwfslayer.c:948: error: ‘psInfo’ undeclared (first use in this
function)
mapwfslayer.c:951: error: syntax error before ‘)’ token
mapwfslayer.c:958: error: syntax error before ‘if’
mapwfslayer.c: In function ‘msWFSLayerGetExtent’:
mapwfslayer.c:975: error: ‘msWFSLayerInfo’ undeclared (first use in this
function)
mapwfslayer.c:975: error: ‘psInfo’ undeclared (first use in this
function)
mapwfslayer.c:978: error: syntax error before ‘)’ token
mapwfslayer.c:985: error: syntax error before ‘if’
mapwfslayer.c: In function ‘msWFSLayerGetItems’:
mapwfslayer.c:1007: error: ‘msWFSLayerInfo’ undeclared (first use in
this function)
mapwfslayer.c:1007: error: ‘psInfo’ undeclared (first use in this
function)
mapwfslayer.c:1010: error: syntax error before ‘)’ token
mapwfslayer.c:1017: error: syntax error before ‘if’
make: *** [mapwfslayer.o] Error 1
Steve
