[mapserver-dev] Build error in trunk...
Yewondwossen Assefa
yassefa at dmsolutions.ca
Fri Oct 16 13:05:17 EDT 2009
It should be fixed now (r9471).
regards,
Steve Lime wrote:
> Hi all: I'm getting an error when compiling without WFS client support:
> mapwfslayer.c: In function ‘msWFSLayerGetShape’:
> mapwfslayer.c:918: error: ‘msWFSLayerInfo’ undeclared (first use in this
> function)
> mapwfslayer.c:918: error: (Each undeclared identifier is reported only
> once
> mapwfslayer.c:918: error: for each function it appears in.)
> mapwfslayer.c:918: error: ‘psInfo’ undeclared (first use in this
> function)
> mapwfslayer.c:921: error: syntax error before ‘)’ token
> mapwfslayer.c: At top level:
> mapwfslayer.c:928: error: syntax error before ‘if’
> mapwfslayer.c: In function ‘msWFSLayerNextShape’:
> mapwfslayer.c:948: error: ‘msWFSLayerInfo’ undeclared (first use in this
> function)
> mapwfslayer.c:948: error: ‘psInfo’ undeclared (first use in this
> function)
> mapwfslayer.c:951: error: syntax error before ‘)’ token
> mapwfslayer.c:958: error: syntax error before ‘if’
> mapwfslayer.c: In function ‘msWFSLayerGetExtent’:
> mapwfslayer.c:975: error: ‘msWFSLayerInfo’ undeclared (first use in this
> function)
> mapwfslayer.c:975: error: ‘psInfo’ undeclared (first use in this
> function)
> mapwfslayer.c:978: error: syntax error before ‘)’ token
> mapwfslayer.c:985: error: syntax error before ‘if’
> mapwfslayer.c: In function ‘msWFSLayerGetItems’:
> mapwfslayer.c:1007: error: ‘msWFSLayerInfo’ undeclared (first use in
> this function)
> mapwfslayer.c:1007: error: ‘psInfo’ undeclared (first use in this
> function)
> mapwfslayer.c:1010: error: syntax error before ‘)’ token
> mapwfslayer.c:1017: error: syntax error before ‘if’
> make: *** [mapwfslayer.o] Error 1
> Steve
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
