[mapserver-dev] help:create maps on the fly without having a map file
Sumit Sharma sumit321 at hotmail.com
Mon Oct 19 01:29:20 EDT 2009
Not just you can create mapObj, and add layers in your map, you can also save
your map obj. It will create map file for you as per the syntax followed by
mapserver. you can then use this map file for futhre use.
View this message in context: http://n2.nabble.com/help-create-maps-on-the-fly-without-having-a-map-file-tp3755763p3847297.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
