[mapserver-dev] strange behavior when size != gif size (UMN 5.4.2)
Steve Lime
Steve.Lime at dnr.state.mn.us
Tue Sep 1 00:42:38 EDT 2009
Daniel: I just ran some local tests against the 5.4 branch and don't see the problem on my dev box (MacOS). I'm using the sample image you supplied and a mapfile like the one below. I'm using GD 2.0.35. Are you still having the issue? Perhaps something weird like multiple versions of GD on the system could cause artifacts like this.
Steve
MAP
NAME 'testy'
SIZE 200 200
EXTENT 0 0 200 200
IMAGETYPE PNG2
OUTPUTFORMAT
NAME PNG2
DRIVER 'GD/PNG'
MIMETYPE 'image/png'
IMAGEMODE RGB
EXTENSION 'png'
END #OUTPUTFORMAT
SYMBOL
NAME 'some_gif_symbol'
TYPE PIXMAP
IMAGE "some_gif_symbol.gif"
END
LAYER
NAME 'too_small'
TYPE POINT
STATUS DEFAULT
FEATURE
POINTS 30 20 END
END
CLASS
STYLE
SYMBOL 'some_gif_symbol'
SIZE 10 # equals gif size -3
END
END
END
LAYER
NAME 'too_large'
TYPE POINT
STATUS DEFAULT
FEATURE
POINTS 50 100 END
END
CLASS
STYLE
SIZE 16 # equals gif size +3
END
END
END
LAYER
NAME 'just_right'
TYPE POINT
STATUS DEFAULT
FEATURE
POINTS 100 50 END
END
CLASS
STYLE
SIZE 13
END
END
END
END
>>> teeschke <daniel.teske at web.de> 08/20/09 10:24 AM >>>
OUTPUTFORMAT
NAME png
DRIVER 'GD/PNG'
IMAGEMODE RGB
EXTENSION 'png'
END #OUTPUTFORMAT
View this message in context: http://n2.nabble.com/strange-behavior-when-size-gif-size-UMN-5-4-2-tp3479658p3479813.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
