[mapserver-dev] strange behavior when size != gif size (UMN 5.4.2)
Steve Lime
Steve.Lime at dnr.state.mn.us
Thu Sep 3 09:22:17 EDT 2009
I will... In your version line there's 'SUPPORTS=RGBA_PNG' which is the signature for
the experimental PNG support. Wonder what versions are used by mapserver and then
GD? Does IMAGETYPE JPEG work for you?
Steve
>>> teeschke <daniel.teske at web.de> 09/03/09 4:00 AM >>>
Can you check your output with a GetMap-Request using &FORMAT=image/png?
I'm using the cgi-bin folder from the "Mapserver 5.4.2 release" that is
packed in the ms4w_3.0_beta6. downloaded from maptools.org
here is the mapserv -v result
MapServer version 5.4.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF
OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
SUPPORTS=ICO
NV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
SUP
PORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS
INPUT=ORA
CLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Steve Lime wrote:
> I've been using shp2img. Just tried on another box with 5.4.2 with the
> attached result (verbatim mapfile I posted earlier).
> Are you using the experimental PNG support by chance? Wouldn't think that
> would have an impact but I think that links
> MapServer against libpng. GD also links against libpng and perhaps there
> is confusion there if the versions are different?
> Steve
>>>> On 9/2/2009 at 3:15 AM, in message
>>>> <1251879359097-3565396.post at n2.nabble.com>,
> teeschke <daniel.teske at web.de> wrote:
>> Hello Steve..
>> I can recreate the wrong output with your sample-map.
>> I added an projection
>> PROJECTION
>> 'init=epsg:31466'
>> END #PROJECTION
>> Now I can fire my GetMap-Request:
>> http://localhost/cgi-bin_ms5.4.2/mapserv.exe?LAYERS=too_small,too_large,just_
>> right&SRS=EPSG:31466&FORMAT=image/png&WIDTH=200&HEIGHT=200&SERVICE=WMS&VERSION=1.1.
>> 1&STYLES=&BBOX=0,0,200,200&map=C:/umn_maps/test/symbol_problem.map&REQUEST=GetMap
>> http://n2.nabble.com/file/n3565396/output.png
>> I found out that when I using FORMAT=image/gif the output looks nice:
>> right&SRS=EPSG:31466&FORMAT=image/gif&WIDTH=200&HEIGHT=200&SERVICE=WMS&VERSION=1.1.
>> http://n2.nabble.com/file/n3565396/output.gif
>> I also tryed to use a gif-symbol, but no change, same problem.
>> Do you using the Mapservers own CGI-Request or WMS-Request?
>> thanks, regards,
>> Daniel
>> Steve Lime wrote:
>>> Daniel: I just ran some local tests against the 5.4 branch and don't see
>>> the problem on my dev box (MacOS). I'm using the sample image you
>>> supplied
>>> and a mapfile like the one below. I'm using GD 2.0.35. Are you still
>>> having the issue? Perhaps something weird like multiple versions of GD
>>> on
>>> the system could cause artifacts like this.
>>> Steve
>>> MAP
>>> NAME 'testy'
>>> SIZE 200 200
>>> EXTENT 0 0 200 200
>>> IMAGETYPE PNG2
>>> OUTPUTFORMAT
>>> NAME PNG2
>>> DRIVER 'GD/PNG'
>>> MIMETYPE 'image/png'
>>> IMAGEMODE RGB
>>> EXTENSION 'png'
>>> END #OUTPUTFORMAT
>>> SYMBOL
>>> NAME 'some_gif_symbol'
>>> TYPE PIXMAP
>>> IMAGE "some_gif_symbol.gif"
>>> END
>>> LAYER
>>> NAME 'too_small'
>>> TYPE POINT
>>> STATUS DEFAULT
>>> FEATURE
>>> POINTS 30 20 END
>>> END
>>> CLASS
>>> STYLE
>>> SYMBOL 'some_gif_symbol'
>>> SIZE 10 # equals gif size -3
>>> END
>>> END
>>> END
>>> LAYER
>>> NAME 'too_large'
>>> TYPE POINT
>>> STATUS DEFAULT
>>> FEATURE
>>> POINTS 50 100 END
>>> END
>>> CLASS
>>> STYLE
>>> SIZE 16 # equals gif size +3
>>> END
>>> END
>>> END
>>> LAYER
>>> NAME 'just_right'
>>> TYPE POINT
>>> STATUS DEFAULT
>>> FEATURE
>>> POINTS 100 50 END
>>> END
>>> CLASS
>>> STYLE
>>> SIZE 13
>>> END
>>> END
>>> END
>>> END
>>>>>> teeschke <daniel.teske at web.de> 08/20/09 10:24 AM >>>
>>> OUTPUTFORMAT
>>> NAME png
>>> DRIVER 'GD/PNG'
>>> IMAGEMODE RGB
>>> EXTENSION 'png'
>>> END #OUTPUTFORMAT
>>> View this message in context:
>> http://n2.nabble.com/strange-behavior-when-size-gif-size-UMN-5-4-2-tp3479658p3479813.ht
>> ml
>>> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
View this message in context: http://n2.nabble.com/Re-strange-behavior-when-size-gif-size-UMN-5-4-2-tp3558359p3572036.html
