[mapserver-dev] hoto add new key in mapfiles
Daniel Morissette
dmorissette at mapgears.com
Fri Sep 4 07:12:29 EDT 2009
Martin Kofahl wrote:
> Hi,
> I currently investigate possibilities of adding per-layer spatial obligation to mapserver. I would like to have a new key 'restriction' for then layer section, but can not find the maplexer files documented. Can you give me a hint, please.
You need to add the new keyword to maplexer.l (note the alphabetical
order) and add an id for it in mapfile.h. Flex should take care of the
rest next time you run make.
BTW, what do you mean by "spatial obligation"? A spatial filter? I can
see how that could be useful in some cases. Are you thinking of
specifying only a BBOX as filter or would a polygon filter also be
supported?
Daniel
Daniel Morissette
http://www.mapgears.com/
