[mapserver-dev] hoto add new key in mapfiles
Martin Kofahl
M.Kofahl at gmx.net
Mon Sep 7 10:27:39 EDT 2009
Thank you, Daniel. I got it working and will open a new enhancement request after cleaning up the code. There's probably much more to do.
One thing I'm missing now is to use environment variables such as REMOTE_USER in DATA/FILTER-strings. I know substitution is working using the query_string.
Martin
-------- Original-Nachricht --------
> Datum: Fri, 04 Sep 2009 07:12:29 -0400
> Von: Daniel Morissette <dmorissette at mapgears.com>
> An: mapserver-dev at lists.osgeo.org
> Betreff: Re: [mapserver-dev] hoto add new key in mapfiles
> Martin Kofahl wrote:
> > Hi,
> > I currently investigate possibilities of adding per-layer spatial
> obligation to mapserver. I would like to have a new key 'restriction' for then
> layer section, but can not find the maplexer files documented. Can you give
> me a hint, please.
> You need to add the new keyword to maplexer.l (note the alphabetical
> order) and add an id for it in mapfile.h. Flex should take care of the
> rest next time you run make.
> BTW, what do you mean by "spatial obligation"? A spatial filter? I can
> see how that could be useful in some cases. Are you thinking of
> specifying only a BBOX as filter or would a polygon filter also be
> supported?
> Daniel
