[mapserver-dev] mapserver performance windows/linux
JUDD.CHRISTOPHER
JUDD.CHRISTOPHER at flsenate.gov
Fri Sep 18 09:32:33 EDT 2009
The url to the spreadsheet got wrapped somehow, here is a tiny url link
to it just in case anyone has problems accessing it.
http://tinyurl.com/l3myam
-Chris
-----Original Message-----
[mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of
JUDD.CHRISTOPHER
Sent: Friday, September 18, 2009 9:28 AM
To: Jeff McKenna; mapserver-dev at lists.osgeo.org
Subject: RE: [mapserver-dev] mapserver performance windows/linux
Jeff,
We greatly appreciate the support from the mapserver development
community.
I've put together a google spreadsheet with all of the data that I have
collected for diagnosing the performance of using the "ANGLE FOLLOW"
attribute. The link is below. I've also attached the updated php and
mapscript files that used, the data and everything else remains the
same. These can be dropped into the original test set
http://c0342891.cdn.cloudfiles.rackspacecloud.com/test.tar (I updated
the paths to fit the different OSes).
I did the testing using the following commands:
Windows: timethis shp2img -m test2.map -o image.gif
Linux: time shp2img -m test2.map -o image.gif
According to my test results, it looks like ms4w 3 beta 7 is slower than
ms4w 2.3.1. Versions 5.0 and 5.4 on Linux appear have similar
performance characteristics (please note that I tested the 5.0 version
on the Rackspace cloud 256MB, so its not a direct comparison but I think
it shows the performance was an issue even at the 5.0 release).
Let me know if you would like me produce any more test results.
http://spreadsheets.google.com/pub?key=tI2bYJ6cs0GarV9OIQRGatQ&output=ht
ml
Thank you for your help,
Chris
[mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
Sent: Thursday, September 17, 2009 3:59 PM
To: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] mapserver performance windows/linux
JUDD.CHRISTOPHER wrote:
> Andy,
> That looks pretty close to the numbers that I am getting.
> Steve, will that suffice for the profiling? I guess it would be nice
to
> look at the differences between ms4w 2.3.1 and 3 beta 7.
> I'd like to do whatever I can to help identify this as a bug and try
to
> get it fixed.
> Thanks,
> Chris
Chris,
Maybe I missed this, but can you state your shp2img draw time results
for MapServer 5.4.2 on Windows and Linux for your test dataset? Are
they the same? If yes, then are you saying that the problem is with
MapServer 5.4.2 only?
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
mapserver-dev mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
