[mapserver-dev] GD, filled ellipse,
rendering: fill is bleeding outside the outline
Havard Tveite
havard.tveite at umb.no
Mon Sep 21 04:48:36 EDT 2009
When using GD, the fill of an outlined filled ellipse symbol
will "bleed" by one pixel several places outside of the
outline for most symbol sizes (Mapserver 5.4.2). See the
attached (magnified) image.
(AGG does not seem to have this problem)
This seems to be a bug. Has it been filed yet?
Here are the most relevant parts of the map file:
SYMBOL
NAME "circle"
TYPE ellipse
FILLED true
POINTS
1 1
END
END
LAYER # Circle - outline
NAME "circ"
PROJECTION
"init=epsg:32633"
END
TYPE POINT
FEATURE
POINTS
50 800
END
END
CLASS
NAME "Circle"
STYLE
SYMBOL 'circle'
SIZE 42
COLOR 0 150 200
OUTLINECOLOR 0 0 0
END
END
END #layer circle - outline
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090921/b05e0940/bleeding.png
