[mapserver-dev] GD, filled ellipse,rendering: fill is bleeding
outside the outline
Havard Tveite
havard.tveite at umb.no
Mon Sep 21 10:51:34 EDT 2009
Sounds reasonable to assume that this is a GD bug.
My Mapserver is using GD version 2.0.35, which should
be the latest one.
Håvard
Steve Lime wrote:
> It's a GD bug I imagine. Have you tried the latest version of that lib?
> Steve
>>>> Havard Tveite <havard.tveite at umb.no> 09/21/09 4:14 AM >>>
> When using GD, the fill of an outlined filled ellipse symbol
> will "bleed" by one pixel several places outside of the
> outline for most symbol sizes (Mapserver 5.4.2). See the
> attached (magnified) image.
> (AGG does not seem to have this problem)
> This seems to be a bug. Has it been filed yet?
> Here are the most relevant parts of the map file:
> SYMBOL
> NAME "circle"
> TYPE ellipse
> FILLED true
> POINTS
> 1 1
> END
> END
> LAYER # Circle - outline
> NAME "circ"
> PROJECTION
> "init=epsg:32633"
> END
> TYPE POINT
> FEATURE
> POINTS
> 50 800
> END
> END
> CLASS
> NAME "Circle"
> STYLE
> SYMBOL 'circle'
> SIZE 42
> COLOR 0 150 200
> OUTLINECOLOR 0 0 0
> END
> END
> END #layer circle - outline
