[mapserver-dev] Need help chopping Image into tiles using mapserver
C code
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Sep 23 19:02:44 EDT 2009
Hi all,
I'm writing some C code using Mapserver to generate an image and then
chop it into tiles and save the tiles. The basic flow is like:
oImg = msDrawMap(map, MS_FALSE);
ret = msSaveImage(NULL, oImg, szMetaImg); /* save/debug metatile */
for tile rows {
for tile columns {
oTile = msImageCreateGD(tileWidth, tileHeight, oImg->format,
NULL, NULL);
msImageCopyMerge(oImg->img.gd, oTile->img.gd, 0, 0, tileLeft,
tileTop, tileWidth, tileHeight, 100);
ret = msSaveImage(NULL, oTile, buf);
msFreeImage(oTile);
msFreeImage(oImg);
My problem is that the metatile looks great, but all the tiles are
black. Traning through the mapserver code in msImageCopyMerge() it is
not using the gdImageCopyMerge() and running through the for loops.
Looping at the tile images in photoshop, it looks like the pixel values
are getting set to rgb(4,2,4), the background of the oImg, the src
image, id rgb(128,177,211)
Does anyone have a clue on what I am missing here?
-Steve W
in gdb oTile looks substantially like oImg
Breakpoint 2, main (argc=4, argv=0x7fffffccd268) at precache3ibeta2.c:860
860 oTile =
msImageCreateGD(tileWidth, tileHeight, oImg->format, NULL, NULL);
(gdb) p oImg
$1 = (imageObj *) 0x640870
(gdb) p *oImg
$2 = {width = 1680, height = 1680, imagepath = 0x63f880 "",
imageurl = 0x63f970 "", format = 0x60db80, imageextra = 0x1187b00,
buffer_format = 1, renderer = 0, size = 0, img = {gd = 0x6b4850,
svg = 0x6b4850, imagemap = 0x6b4850 "", raw_16bit = 0x6b4850,
raw_float = 0x6b4850, raw_byte = 0x6b4850 ""}}
(gdb) p *oImg->format
$3 = {name = 0x60dac0 "agg", mimetype = 0x60db20 "image/png",
driver = 0x60dbd0 "AGG/PNG", extension = 0x60db00 "png", renderer = 7,
imagemode = 1, transparent = 0, bands = 1, numformatoptions = 1,
formatoptions = 0x60dc10, refcount = 3, inmapfile = 1}
(gdb) n
861 if (!oTile) {
(gdb)
865 msImageCopyMerge(oImg->img.gd,
oTile->img.gd, 0, 0, tileLeft, tileTop, tileWidth, tileHeight, 100);
(gdb) p *oTile
$4 = {width = 200, height = 200, imagepath = 0x0, imageurl = 0x0,
format = 0x60db80, imageextra = 0x0, buffer_format = 0, renderer = 0,
size = 0, img = {gd = 0x11be030, svg = 0x11be030, imagemap =
0x11be030 "",
raw_16bit = 0x11be030, raw_float = 0x11be030, raw_byte = 0x11be030 ""}}
(gdb) p *oTile->format
$5 = {name = 0x60dac0 "agg", mimetype = 0x60db20 "image/png",
formatoptions = 0x60dc10, refcount = 4, inmapfile = 1}
(gdb) p *oTile->format->formatoptions
$6 = 0x60db60 "INTERLACE=false"
