[mapserver-dev] Error accessing Shape files w/no
attributes
Steve Lime
Steve.Lime at dnr.state.mn.us
Tue Sep 29 11:04:49 EDT 2009
Jim: Create a quick ticket and I'll take care of applying your patch tonite.
Steve
>>> On 9/28/2009 at 2:38 PM, in message <4AC0CA720200004F000142A1 at jeckle>, "Jim
Klassen" <Jim.Klassen at ci.stpaul.mn.us> wrote:
> When I try to access a layer that points to a shape file with no attributes I
> get the following error...
> msDrawMap(): Image handling error. Failed to draw layer named 'CITYOUTLINE'.
> msGetDBFItems(): DBASE file error. File contains no data.
> It looks like this is related to a change introduced with the improved
> algorithm in msLayerWhichItems() in maplayer.c. The problem seems to be how
> lines 385 and 386 are interacting with msDBFGetItems/msShapeFileLayerGetItems
> in that msShapeFileLayerGetItems is returning MS_FAILURE because
> msDBFGetItems found no items and thus calls msSetError and returns NULL. The
> line maplayer.c:386 then causes msLayerWhichItems to fail before line 388 can
> say this is an expected condition.
> 385 rv = msLayerGetItems(layer);
> 386 if(rv != MS_SUCCESS) return rv;
> 387
> 388 if(layer->numitems == 0) return MS_SUCCESS; /* nothing to do but not an
> error */
> The following are the changes I made to mapshape.c (to return MS_SUCCESS)
> and to mapxbase.c to not set an error that isn't an error. The change to
> mapxbase.c may cause issues with tileindexed layers with no attributes in the
> tileindex shapefile failing without an error message. This depends on what
> the correct behavior is in another place in msTiledSHPLayerGetItems. I think
> this is for the tileindex not the actual data shapes, and the tileindex does
> require at least one attribute. If this is true and the mapxbase.c change is
> kept, an error probably needs to be set in msTiledSHPLayerGetItems if there
> are no items.
> Index: mapshape.c
> --- mapshape.c (revision 9354)
> +++ mapshape.c (working copy)
> @@ -2579,6 +2579,7 @@
> layer->numitems = msDBFGetFieldCount(shpfile->hDBF);
> layer->items = msDBFGetItems(shpfile->hDBF);
> + if(layer->numitems == 0) return MS_SUCCESS; /* No items is a valid case */
> if(!layer->items) return MS_FAILURE;
> return msLayerInitItemInfo(layer);
> Index: mapxbase.c
> --- mapxbase.c (revision 9354)
> +++ mapxbase.c (working copy)
> @@ -824,7 +824,7 @@
> char fName[32];
> if((nFields = msDBFGetFieldCount(dbffile)) == 0) {
> - msSetError(MS_DBFERR, "File contains no data.", "msGetDBFItems()");
> + /*msSetError(MS_DBFERR, "File contains no data.", "msGetDBFItems()");*/
> return(NULL);
> James Klassen
> Office of Technology and Communications
> 15 West Kellogg Blvd
> Saint Paul, MN 55102
> P: 651-329-8741
> USNG: 15TVK92577674
> ( http://www.stpaul.gov/ )
> Making Saint Paul the Most Livable City in America
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
