[mapserver-dev] PATCH: output CONNECTIONTYPE for join object
strk
strk at keybit.net
Wed Apr 21 03:51:13 EDT 2010
For the record, I filed it now (thanks crschmidt for fixing trac):
http://trac.osgeo.org/mapserver/ticket/3435
--strk;
On Tue, Apr 20, 2010 at 10:39:15PM +0200, strk wrote:
> A patch is attached for review.
> It implements output for CONNECTIONTYPE parameter of JOIN
> object, currently just ignored.
> I didn't actually test myself yet.
> --strk;
> On Tue, Apr 20, 2010 at 05:09:25PM +0200, strk wrote:
> > Hi all,
> > I'm trying to setup a JOIN between a PostgreSQL table
> > and a CSV file.
> > Documentation [1] contains an example of Shapfile to CSV,
> > I tried it with POSTGIS to CSV but didn't have luck.
> > In particular, I get this error:
> > msDBFJoinConnect(): Unable to access file.
> > I have NOT specified a CONNECTIONTYPE, and the documentation
> > says that's supposed to just work with CSV, so can't understand
> > why msDBFJoinConnect is being called.
> > I've taken a look at the mapserver trunk code and found
> > that a join's connectiontype is initialized to XBASE
> > mapfile.c:void initJoin(joinObj *join):
> > join->connectiontype = MS_DB_XBASE;
> > So I tried explicitly asking for CSV instead, adding a CONNECTIONTYPE
> > string. BUT, I'm doing the mapfile using mapscript and I don't
> > find the CONNECTIONTYPE part in the resulting mapfile after save.
> > No wonder, as the JOIN writer isn't writing anything for that !
> > ref: mapfile.c:static void writeJoin(joinObj *join, FILE *stream)
> > Can we call it a couple of bugs ?
> > [1] http://mapserver.org/mapfile/join.html
> > --strk;
> > () Free GIS & Flash consultant/developer
> > /\ http://strk.keybit.net/services.html
> > mapserver-dev mailing list
> > mapserver-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Index: mapfile.c
> --- mapfile.c (revision 10107)
> +++ mapfile.c (working copy)
> @@ -566,6 +566,19 @@
> if(join->name) fprintf(stream, " NAME \"%s\"\n", join->name);
> if(join->table) fprintf(stream, " TABLE \"%s\"\n", join->table);
> if(join->to) fprintf(stream, " TO \"%s\"\n", join->to);
> + switch (join->connectiontype) {
> + case(MS_DB_CSV):
> + fprintf(stream, " CONNECTIONTYPE csv\n");
> + break;
> + case(MS_DB_MYSQL):
> + fprintf(stream, " CONNECTIONTYPE mysql\n");
> + break;
> + case(MS_DB_POSTGRES):
> + fprintf(stream, " CONNECTIONTYPE postgresql\n");
> + break;
> + default:
> + break;
> fprintf(stream, " TYPE %s\n", msJoinType[join->type]);
> fprintf(stream, " END\n");
