[mapserver-dev] possible incomplet mapscript documentation ?
Oliver Christen
oliver.christen at camptocamp.com
Mon Apr 26 09:29:39 EDT 2010
Thank you Alan,
that confirms what I presumed
is it ok if I open a documentation bug for this ?
regards
Oliver
> Hi Olivier,
> IIRC, MS_DONE simply means that the layer do not apply to the current
> query
> executed. ie. A queryByRect when the rect does not overlap the bounds of
> the
> layer. Also, if the layer is set to ignore missing data, it may returns
> MS_DONE.
> Alan
> On April 26, 2010 04:10:50 am Oliver Christen wrote:
>> Hello
>> With php mapscript and swig mapscript, I noticed the whichShapes function
>> returns sometime a code "2", which is not documented.
>> I looked at Mapserver and Mapscript source code (I dont know C so I just
>> followed the logical calls)
>> whichShapes calls for msLayerWhichShapes or return MS_FAILURE
>> *msLayerWhichShapes calls for msInitializeVirtualTable and
>> LayerWhichShapes
>> **msInitializeVirtualTable calls for destroyVirtualTable,
>> createVirtualTable, and (in my case)
>> msShapeFileLayerInitializeVirtualTable
>> or returns MS_FAILURE
>> ***destroyVirtualTable returns MS_SUCCESS
>> ***createVirtualTable calls for populateVirtualTable or returns
>> MS_FAILURE
>> ****populateVirtualTable return only MS_SUCCESS
>> ***msShapeFileLayerInitializeVirtualTable return only MS_SUCCESS
>> **LayerWhichShapes is msShapeFileLayerWhichShapes in my case
>> ***msShapeFileLayerWhichShapes calls for msShapefileWhichShapes or
>> returns
>> MS_FAILURE
>> ****msShapefileWhichShapes returns MS_DONE, MS_FAILURE or MS_SUCCESS
>> if I do :
>> print mapscript.MS_DONE
>> (with python swig mapscript)
>> I get 2 so here is my culprit
>> so,
>> 1) it seems the documentation in incomplet, mapscript whichshapes can
>> return MS_SUCCESS, MS_FAILURE or MS_DONE (and not only MS_SUCCESS or
>> MS_FAILURE )
>> 2) what means exactly MS_DONE ?
>> the code is in mapshape.c in function msShapefileWhichShapes :
>> /* rect and shapefile DON'T overlap... */
>> if(msRectOverlap(&shpfile->bounds, &rect) != MS_TRUE)
>> return(MS_DONE);
>> does that means the requested rect is completly outside of the shapefile
>> bbox ?
>> anyone can confirm that ?
>> thanks in advance
>> Oliver
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Alan Boudreault
> Mapgears
> http://www.mapgears.com
