[mapserver-dev] Re:#3265 - Scale dependent layer switching error
with Mercator
relet
thomas.hirsch at statkart.no
Tue Apr 27 02:46:25 EDT 2010
Hi all,
I have been trying to solve an issue we have with the mapserver rendering
detail level when using different projections and the MAXSCALEDENOM limits.
http://osgeo-org.1803224.n2.nabble.com/Layer-scale-problem-with-Mercator-EPSG-900913-td2575585.html
To this aim, I have implemented the idea mentioned there by Pål, to specify
different scale denominator limits for different projections
http://trac.osgeo.org/mapserver/ticket/3265
Now I am struggling to find a good place in the Mapfile syntax for this.
Currently, I have crudely attached the projection string to the
MAXSCALEDENOM parameter, where it is possibly the most straightforward for
people who need this feature. But as Daniel correctly pointed out, it's a
quite specific implementation, and no reason to extend the general syntax.
The same argument would certainly apply to the internal objects. E.g.
layerObj, where I grouped the various scale denominators with a scaleObj, to
be able to store several of them in a hashtable, indexed by the epsg codes.
Hence, I am looking forward to any suggestions how to contribute this
feature in a generic, but user-friendly way.
Thank you all in advance,
best regards,
Thomas
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Re-3265-Scale-dependent-layer-switching-error-with-Mercator-tp4966902p4966902.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
