[mapserver-dev] mode=tile dependency on GDAL
Roger André
randre at gmail.com
Fri Apr 30 18:52:54 EDT 2010
Hi All,
I've encountered something that I haven't seen before - a MapServer instance
that was compiled without GDAL. I'm trying to use it to serve up tiles in
"mode=tile" from a large raster. I've encountered 2 errors so far, one
saying that GDAL was needed for display of RGB or RGBA images, the other
saying that it was needed to reproject the source data to EPSG:900913.
I'm curious if there is any way I can pre-process my raster data so that it
will work on this MapServer instance? I've tried turning off all
OUTPUTFORMAT declarations, and pre-warping the raster to EPSG:900913, but I
still am getting the reprojection error.
Thanks in advance,
Roger
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20100430/7cbec332/attachment.html
