[mapserver-dev] FW: [MapServer] #3519: map UNITS AUTO from
PROJECTION units
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Wed Aug 18 11:06:35 EDT 2010
Seems like a reasonable idea but also one that I would think has been discussed
before. Thoughts?
Steve
-----Original Message-----
Sent: Wednesday, August 18, 2010 4:41 AM
Subject: [MapServer] #3519: map UNITS AUTO from PROJECTION units
Reporter: regodon | Owner: sdlime
Type: enhancement | Status: new
Priority: normal | Milestone:
Component: MapServer C Library | Version: unspecified
Severity: normal | Keywords:
I think that map UNITS should be initialized automatically depending on
the PROJECTION used.
Is there any sense in using a projection in meters (UTM) and setting map
UNITS in degrees?
Since a wms client can ask for a map in different projections, i think map
UNITS should be automatically detected. Otherwise any layer with SIZEUNITS
other than pixels is drawn wrongly when map units are different from
projection units.
Ticket URL: <http://trac.osgeo.org/mapserver/ticket/3519>
MapServer <http://mapserver.org>
