[mapserver-dev] RFC-60: Label enhancement to skip ANGLE FOLLOW
labels with overlapping chars
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Aug 31 13:32:17 EDT 2010
There was a discussion on IRC today on this: GeoServer does not
differentiate between outside vs inside overlapping labels, it just
discards any label with an overlap angle greater than 22.5 degrees.
I have to admit that I have read the descriptions several times for
negative vs positive MAXOVERLAPANGLE and it is still confusing to me.
If we do enable both, can you define better what the "inside" and
"outside" of a line is?
thanks.
-jeff
On 10-08-27 6:03 PM, Daniel Morissette wrote:
> Jeff, could you try to find out what GeoServer does? Does it exclude
> both cases, or only the labels that overlap on the inside of the curve?
