[mapserver-dev] RFC 65 - Single pass query handling for 6.0
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Thu Dec 2 13:11:43 EST 2010
Excellent. The RFC as a whole is ok from your perspective then?
Steve
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Thursday, December 02, 2010 11:29 AM
To: Lime, Steve D (DNR)
Cc: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] RFC 65 - Single pass query handling for 6.0
I'm about to implement some kind of support for the single pass option in the mssql2008 driver.
Tamas
2010/12/2 Lime, Steve D (DNR) <Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us>>
Sweet. Thanks for confirming. How does that help you?
Steve
From: Tamas Szekeres [mailto:szekerest at gmail.com<mailto:szekerest at gmail.com>]
Sent: Thursday, December 02, 2010 10:53 AM
Cc: mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>
Yes, it looks good. I didn't notice it has already been implemented.
Tamas
2010/11/30 Lime, Steve D (DNR) <Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us>>
Is the idea of accessing the queryObj through layer->map->query not ok? That object stores the type of query and the type is set to MS_QUERY_IS_NULL if in draw mode.
Steve
________________________________________
From: Tamas Szekeres [szekerest at gmail.com<mailto:szekerest at gmail.com>]
Sent: Monday, November 29, 2010 1:20 PM
Steve,
Would it be a big effort to include that additional parameter passed to the driver (in time of the whichShapes call) to make sure about the purpose of the query? This would help the driver to decide whether a single row forward only cursor is sufficient or a block based approach should be used at the 'low level' driver when retrieving the data from the server.
Best regards,
Tamas
2010/11/29 Lime, Steve D (DNR) <Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us><mailto:Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us>>>
FYI I updated RFC 65 with a bit more detail on implementation and impact... Again, feedback most welcome.
Steve
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20101202/86f703c9/attachment.html
