[mapserver-dev] Mapserver numeric formatting of labels
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Fri Dec 10 13:41:59 EST 2010
Note that treating TEXT (...) as true expressions is a regression (this is in the RFC) but doing so really opens up the possibilities.
Steve
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Tamas Szekeres
Sent: Friday, December 10, 2010 12:32 PM
To: Lime, Steve D (DNR)
Cc: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] Mapserver numeric formatting of labels
Steve,
Thanks for the update this was really helpful.
Best regards,
Tamas
2010/12/10 Lime, Steve D (DNR) <Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us>>
The work for RFC 64 has support for this already. I'll have to go back to my notes for more detail but I think this is correct:
Case 1: using LABELITEM... In this instance you get the full representation of the of the number according to the DBF definitions. If you access a numeric column in string context in an logical expression you'll also get this (e.g. '[numcol]').
Case 2: using TEXT expression with no transformation and numeric context (e.g. TEXT ([numcol])). This forces the number through the new expression handling. In this case we have to do a conversion from a number to a string and the default format I chose was "%g" which results in some relatively reasonable trimming.
Case 3: using TEXT expression with transformations. I added several functions to the parser to help in this regard:
Round(num, num) (e.g. round([numcol], 2))
Tostring(num, format) (e.g. tostring([numcol], "%.2f"), note this truncates so you might want to round and then convert to string)
Commify(string) (e.g. commify('[numcol]'), typically you'd do this after converting to a string so 20000.00 would become 20,000.00)
It's pretty flexible although there's almost certainly room for improvement.
Steve
From: mapserver-dev-bounces at lists.osgeo.org<mailto:mapserver-dev-bounces at lists.osgeo.org> [mailto:mapserver-dev-bounces at lists.osgeo.org<mailto:mapserver-dev-bounces at lists.osgeo.org>] On Behalf Of Tamas Szekeres
Sent: Friday, December 10, 2010 12:07 PM
To: mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>
Subject: [mapserver-dev] Mapserver numeric formatting of labels
Hi All,
Do we have any plans to support numeric formatting when rendering labels from layer attributes? As far as I remember we had such plans for 6.0, but I'm not sure whether anyone is working on that actually or not.
Any idea for a reasonable approach would also be helpful.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20101210/5a742c83/attachment-0001.html
