[mapserver-dev] WFS query and Postgis cast problem using with
filter encoding
Yewondwossen Assefa
yassefa at dmsolutions.ca
Sat Dec 11 08:45:11 EST 2010
You could possibly try to set a layer level metadata to indicate the type:
"gml_code_dept_type" "Character"
Please also indicate what version of MapServer.
best regards,
On 10/12/2010 8:00 PM, Thomas Gratier wrote:
> Hello list,
> Filter encoding seems to suffer from a type problem with Postgis. I
> want to confirm the problem and check I don't miss something.
> So my use case.
> I have created a Postgis table.
> The structure of the table starts with
> CREATE TABLE departement
> gid serial NOT NULL,
> id_geofla numeric(10,0),
> code_dept character varying(2),
> nom_dept character varying(30),
> the_geom geometry,
> I use this postgis layer in a WFS webservices
> A query like
> http://localhost/cgi-bin/mapserv?map=/home/test/SIG/france/mapfiles/mapfile_carte.map&REQUEST=GetFeature&SERVICE=WFS&VERSION=1.0.0&TYPENAME=departements&OUTPUT=gml
> <http://localhost/cgi-bin/mapserv?map=/home/test/SIG/france/mapfiles/mapfile_carte.map&REQUEST=GetFeature&SERVICE=WFS&VERSION=1.0.0&TYPENAME=departements&OUTPUT=gml>
> works.
> When I use a filter like
> http://localhost/cgi-bin/mapserv?map=/home/test/SIG/france/mapfiles/mapfile_carte.map&REQUEST=GetFeature&SERVICE=WFS&VERSION=1.0.0&TYPENAME=departements&OUTPUT=gml&Filter=
> <http://localhost/cgi-bin/mapserv?map=/home/test/SIG/france/mapfiles/mapfile_carte.map&REQUEST=GetFeature&SERVICE=WFS&VERSION=1.0.0&TYPENAME=departements&OUTPUT=gml&Filter=><Filter><PropertyIsEqualTo><PropertyName>code_dept</PropertyName><Literal>01</Literal></PropertyIsEqualTo></Filter>
> there is an error with the message below.
> <ServiceExceptionReport version="1.2.0"
> xmlns="http://www.opengis.net/ogc"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/ogc
> http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd">
> <ServiceException code="NoApplicableCode" locator="mapserv">
> msWFSGetFeature(): WFS server error. FLTApplyFilterToLayer() failed
> msPostGISLayerWhichShapes(): Query error. Error (ERREUR: l'opérateur
> n'existe pas : character varying = integer LINE 1:
> ...d_srid('','departement','the_geom')) and ( (code_dept= 01) ) ^
> HINT: Aucun opérateur ne correspond au nom donné et aux types
> d'arguments. Vous devez ajouter des conversions explicites de type. )
> executing query: select
> "gid","id_geofla","code_dept","nom_dept",encode(AsBinary(force_collection(force_2d("the_geom")),'NDR'),'hex')
> as geom,"oid" from departement where the_geom &&
> GeomFromText('POLYGON((-25000000 -25000000,-25000000 25000000,25000000
> 25000000,25000000 -25000000,-25000000
> -25000000))',find_srid('','departement','the_geom')) and ( (code_dept=
> 01) )
> </ServiceException>
> </ServiceExceptionReport>
> It seems to come from cast : mapserver receives the parameter from the
> url but doesn't check type and considers the retrieved value as an
> integer (because there is no quotes)
> This problem occurs with Postgis but not with a shapefile (the same
> url works...). I've done some test with oid = true but nothing changes too
> Regards
> ThomasG
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20101211/44378ac2/attachment.html
