[mapserver-dev] Re: [mapserver-users] Using e00 files
Brent Fraser
bfraser at geoanalytic.com
Tue Feb 2 14:03:40 EST 2010
Hmm. I see the problem. The current Mapserver behavior is "if the LAYER proj
is not specified, assume it to be the same as the MAP proj and don't re-project
the coordinates". As Howard points out in RFC, the closest we could get to
simplifying the LAYER proj definition would be:
PROJECTION
AUTO
END
Dunno about where to put the reading of the external SRS. Perhaps when the
Layer Data is set mapscript could attempt to load the SRS. I never could get
PHP mapscript to give me a valid projection object; I seem to have to set them
explicitly within the PHP.
Brent
Paul Ramsey wrote:
> Yeah, would be nice.
> Howard did an RFC some time back.
> http://svn.osgeo.org/mapserver/trunk/docs/en/development/rfc/ms-rfc-37.txt
> I think it could be whittled down to
> if (! layer->projection)
> msLoadProjectionFromSource(lyr);
> The odd/unfortunate thing about that is setting the projection becomes
> a kind of side effect of msDrawMap, probably. At least, the current
> workflow is such that the data sources aren't opened until "things
> start happening" (queries, map drawing, whatever). So either we
> piggyback the source projection setting into there, or we stick it
> onto the end of msLoadMap. But putting the projection load at the end
> of msLoadMap could make for some interesting problems for mapscript
> people who are loading a map file with invalid data entries and then
> making them valid before invoking an action.
> The question of "where in the workflow to do the source projection
> reading" seems like the key one for this problem.
> P.
> On Tue, Feb 2, 2010 at 9:14 AM, Brent Fraser <bfraser at geoanalytic.com> wrote:
>> You haven't defined the LAYER's PROJECTION (we really should enhance
>> mapserver to read .prj files!)
