[mapserver-dev] Regression in 5.6.4
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Jul 10 12:02:37 EDT 2010
I'm not sure when this regression crept in because I'm converting a lot
of older apps over to use 5.6.4. But on 5.2.2 I could draw a layer with
NullShape items in a shapefile without a problem and on 5.6.4 it dies
with a general error message.
msDrawMap(): Image handling error. Failed to draw layer named 'Linear
Water'. msDrawShape(): General error message. Only polygon or line
shapes can be drawn using a line layer definition.
In general, since mapserver is designed for drawing data and not
validating it or being a GIS system in general. I think we should just
step over these records. If we want to be more helpful AND the user has
DEBUG truned on than it would be helpful to say what file and what
record is a NullShape.
I have a huge tileindex that I converted to script like:
# shpdump ./afghanistan_p/major_roads/aflw | grep Shape:
with 128 files and anyones guess on the number of records.
woodbri at carto:/u/data/leaddog$ dbfdump tidx-lw.dbf > bbb
woodbri at carto:/u/data/leaddog$ vi bbb
woodbri at carto:/u/data/leaddog$ sh bbb | grep -v Arc
Shape:0 (NullShape) nVertices=0, nParts=0
Shape:1 (NullShape) nVertices=0, nParts=0
Here is a patch that seems to fix this:
woodbri at carto:/u/software/mapserver-5.6.4$ diff -Naur mapdraw.c
mapdraw.c-orig
--- mapdraw.c 2010-07-10 11:53:17.000000000 -0400
+++ mapdraw.c-orig 2010-07-10 11:57:27.000000000 -0400
@@ -964,7 +964,7 @@
while((status = msLayerNextShape(layer, &shape)) == MS_SUCCESS) {
shape.classindex = msShapeGetClass(layer, &shape,
map->scaledenom, classgroup, nclasses);
- if((shape.type == MS_SHAPE_NULL) || (shape.classindex == -1) ||
(layer->class[shape.classindex]->status == MS_OFF)) {
+ if((shape.classindex == -1) ||
msFreeShape(&shape);
continue;
http://trac.osgeo.org/mapserver/ticket/3487
-Steve W
