[mapserver-dev] FW: [mapserver-users] rendering difference
between 5.6.3 and 5.6.4
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Tue Jul 13 12:44:40 EDT 2010
An area of brittleness, indeed. Thanks for the fast fix!
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Alan Boudreault
Sent: Tuesday, July 13, 2010 10:21 AM
To: mapserver-dev at lists.osgeo.org
Cc: Daniel Morissette
Subject: Re: [mapserver-dev] FW: [mapserver-users] rendering difference between 5.6.3 and 5.6.4
The problem is effectively related to that enum order. It seems that MapServer
doesn't use only the enum name but use the enum integer values (determined by
the enum order) to get the inchesPerUnit values. There is scale/units code in
4 different files, I would say that a cleanup should be done to avoid such
problems in the future.
It's now fixed in trunk and backported in branch 5.6. I'd need someone that
could get the svn branch 5-6 and confirm that the problem is fixed before
Daniel prepares the MS 5.6.5 release. Changeset:
http://trac.osgeo.org/mapserver/changeset/10345
My apologies for any inconvenience I caused >:|
regards,
Alan
On July 13, 2010 10:36:19 am Daniel Morissette wrote:
> Lime, Steve D (DNR) wrote:
> > Probably related to the issue that Steve W. identified yesterday. Time to
> > start digging folks...
> I think the problem may be related to the patch for the units enum order:
> http://trac.osgeo.org/mapserver/ticket/3413
> The patch (r10243) does not seem to sync the inchesPerUnit[] array in
> mapscale.c...
> Checking...
> Daniel
Alan Boudreault
Mapgears
http://www.mapgears.com
mapserver-dev mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
