[mapserver-dev] removing dynamically created layer in mapscript
mapsab
sabuvk at gmail.com
Wed Jul 14 05:27:31 EDT 2010
Hi
As part of implementing a website using mapscript,I have created a function
that draws lines in the map.
It draws the line ,but when I want to redraw the line using some other
points,the first drawn line is still appearing on the map,even after I
removed the layer which I drew earlier for the line.Can any one suggests me
how to remove the earlier layer from the map,so that the last drawn line is
only visible?
The code for drawing the line is given below
Public Sub dra_li(ByVal pointary() As pointObj, ByVal count As Integer)
Dim oTempLayer As layerObj = New layerObj(Util.MSMap)
Dim lno As Integer = Util.MSMap.numlayers
lno = lno
oTempLayer.name = "Userlines"
oTempLayer.status = 1 'change to 1
oTempLayer.type = MS_LAYER_TYPE.MS_LAYER_LINE
Util.MSMap.insertLayer(oTempLayer, lno) '18
Dim i As Integer
Dim oShp As shapeObj = New shapeObj(MS_SHAPE_TYPE.MS_SHAPE_LINE)
For i = 0 To count - 2
Dim oLine As lineObj = New lineObj()
'Dim startpoint1 As New pointObj(58.5818, 23.6011, 0, 0)
'Dim endpoint1 As New pointObj(54.09818, 17.0011, 0, 0)
oLine.add(pointary(i))
oLine.add(pointary(i + 1))
oShp.add(oLine)
Next
Dim oTempClass As classObj = New classObj(oTempLayer)
Dim oStyle As styleObj = New styleObj(oTempClass)
oStyle.color.setRGB(0, 0, 0)
oTempLayer.addFeature(oShp)
Dim oimg As imageObj = Util.MSMap.draw()
oTempLayer.draw(Util.MSMap, oimg) '''un comment to draw this
line
Util.MapIsDirty = True
End Sub
for removing layer i use
Dim tl As layerObj = Util.MSMap.getLayerByName("Userlines")
Util.MSMap.removeLayer(tl.index)
Thanks,
Sam
View this message in context: http://osgeo-org.1803224.n2.nabble.com/removing-dynamically-created-layer-in-mapscript-tp5291745p5291745.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
