[mapserver-dev] problems when compiling mapserver from source code
stephan_82
menno382 at gmx.de
Fri Jul 16 05:44:22 EDT 2010
Hello members!
First I want to apologize for my bad english. I hope that I can explain my
problem still good enough.
I just install mapserver in version 5.6.3. on CENTOS 5.5. When I configure
the source code and then run make, it is an error. I suspect that the
problem is that my OpenSSL library is newer than the mapserver needed.
My ./configure command looks like this:
./configure --with-postgis=/usr/local/pgsql/bin/pg_config
--with-proj
--with-geos
--with-gdal
--with-ogr
--with-wfs
--with-wcs
--with-sos
--with-curl
--with-wmsclient
--with-wfsclient
--with-php=/opt/PostgreSQL/EnterpriseDB-ApachePhp/php
--with-jpeg (but nothing happened)
--with-png (nothing happened)
The error after the make command looks like this.
http://osgeo-org.1803224.n2.nabble.com/file/n5301205/mapserver_fehler.jpg
I hope someone has an idea and can help me solve my problem.
with best wishes from Germany
Stephan
View this message in context: http://osgeo-org.1803224.n2.nabble.com/problems-when-compiling-mapserver-from-source-code-tp5301205p5301205.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
