[mapserver-dev] Rendering Problem
Ibrahim Saricicek
ibrahimsaricicek at gmail.com
Fri Jul 23 04:33:26 EDT 2010
Hi All,
This post was also discussed on Mapserver Users mail group;
http://osgeo-org.1803224.n2.nabble.com/Rendering-Problem-td5069072.html#a5098281
But I can't find a way to solve yet.
Let me explain again;
This is my Debian Lenny 64-bit server Mapserver version;
MapServer version 5.4.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=SOS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS
INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=MYGIS
INPUT=SHAPEFILE
This is my Windows 7 64-bit local Mapserver version;
MapServer version 5.4.0-rc2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
This is my class definition in Map file;
CLASS
NAME "SAGLIK"
MAXSCALEDENOM 13000
EXPRESSION (('[tipi_eng]' = 'HASTANE'))
STYLE
SYMBOL 'hospital_img'
SIZE 27
END
LABEL
COLOR 220 25 35
FONT calibri-bold
TYPE truetype
SIZE 8
POSITION LC
PARTIALS FALSE
OUTLINECOLOR 255 255 255
ALIGN CENTER
WRAP ' '
BUFFER 3
PRIORITY 10
ANTIALIAS TRUE
END
END
And this is the output file rendering definition in Map file;
OUTPUTFORMAT
NAME PNG
DRIVER "GD/PNG"
MIMETYPE "image/PNG"
IMAGEMODE RGB
EXTENSION "PNG"
TRANSPARENT ON
FORMATOPTION "INTERLACE=OFF"
FORMATOPTION "QUANTIZE_COLORS=256"
FORMATOPTION "QUANTIZE_FORCE=ON"
END
And the differences of result can be seen on the image...
http://osgeo-org.1803224.n2.nabble.com/file/n5328765/hybrid.jpg
http://osgeo-org.1803224.n2.nabble.com/file/n5069072/hybrid.jpg
Note:I don't want to use Agg rendering, it doesn't give the result that I
want !!!
This is server side (local version is ms4w 5.4.0-rc2, not the same
libraries!!)
ii libfreetype6 2.3.7-2+lenny1 FreeType 2
font engine, shared library files
ii libfreetype6-dev 2.3.7-2+lenny1 FreeType 2
font engine, development files
ii libgd2-xpm 2.0.36~rc1~dfsg-3+lenny1 GD Graphics
Library version 2
ii libgd2-xpm-dev 2.0.36~rc1~dfsg-3+lenny1 GD Graphics
Library version 2 (development version)
ii libgdal1-1.5.0 1.5.2-3 Geospatial
Data Abstraction Library
ii libgdal1-dev 1.5.2-3 Geospatial
Data Abstraction Library - Development files
ii libgdbm3 1.8.3-3 GNU dbm
database routines (runtime version)
ii libogdi3.2 3.2.0~beta1-3.1 Open
Geographic Datastore Interface Library -- library
ii libpng12-0 1.2.27-2+lenny2 PNG library
- runtime
ii libpng12-dev 1.2.27-2+lenny2 PNG library
- development
ii optipng 0.6.1.1-2 advanced
PNG (Portable Network Graphics) optimizer
ii pngnq 0.5-3 tool for
optimizing PNG (Portable Network Graphics) images
Why on Linux letters are adjacent???
Thanks in Advance...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Rendering-Problem-tp5328765p5328765.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
