[mapserver-dev] MapServer legend functionality
Yewondwossen Assefa yassefa at dmsolutions.ca
Fri Jun 11 13:32:59 EDT 2010
On 11/06/2010 12:13 PM, Kralidis,Tom [Ontario] wrote:
> Assefa: isn't this a GetMap request which outputs a legend image
> instead?  I see similar logic.
> I've seen CubeWerx use 'GetLegend', which displays a full legend, as a
> VendorSpecificParameter in their WMS implementation, which I think is
> very useful.
> ..Tom
Correct, parameters to be able to use this functionality through OGC
would be similar to a GetMap request. I like the idea of having the
GetLegend interface. The other possiblity would have been to access it
through a GetLegendGraphic with vendor specific parameters to
accommodate this.
I was not aware of the CubeWerx GetLegend support. I also  think that It
can be useful. I am not sure though that Cuberx has the concept of
"visible elements only" in the legend support.
regards,
>> -----Original Message-----
>> From: mapserver-dev-bounces at lists.osgeo.org
>> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of
>> Yewondwossen Assefa
>> Sent: Friday, 11 June 2010 12:10
>> To: Lime, Steve D (DNR)
>> Cc: 'MapServer Dev Mailing List'
>> Subject: Re: [mapserver-dev] MapServer legend functionality
>> On 11/06/2010 11:54 AM, Lime, Steve D (DNR) wrote:
>>> I think it would be a reasonable addition. Are you thinking about
>>> simply adding a visibility flag to a layer and flipping it
>> if features
>>> are rendered? Often legend rendering is done separately
>> from drawing, as two separate requests. Presumably you'd need
>> a something like a fake draw map option in the legend code to
>> make a drawing-like pass through the data. Could get expensive.
>>    Yes,  it could be an expensive operation to do a fake draw
>> to get the legend. I am wondering if we could save something
>> when a draw is done and retrieve it for the legend if it
>> validates the current layers/extent  constraint.  Draw and
>> legend are separate process but come usually one after the
>> other so trying to take into account that fact might help.
>> regards
>>> Steve
>>> Yewondwossen Assefa
>>> Sent: Thursday, June 10, 2010 7:24 PM
>>> To: 'MapServer Dev Mailing List'
>>> Subject: [mapserver-dev] MapServer legend functionality
>>> Hi all,
>>>     I was looking into possible solutions re. MapServer
>> legend and the
>>> possibility to only draw a legend (icon and text) based on
>> the current
>>> visible features.
>>> The idea is to have this functionality exposed through
>> interfaces such
>>> as OGC GetLegendGraphic that can provide the drawing
>> "context" (such
>>> as layers, bbox ...). The idea is to allow users to have a
>> reasonable
>>> legend based on what they are drawing.
>>> Do others run into this and see it as a useful addition?
>>> best regards,
>> Assefa Yewondwossen
>> Software Analyst
>> Email: yassefa at dmsolutions.ca
>> http://www.dmsolutions.ca/
>> Phone: (613) 565-5056 (ext 14)
>> Fax:   (613) 565-0925
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Fax:   (613) 565-0925
