[mapserver-dev] MapServer legend functionality
Bob Basques
Bob.Basques at ci.stpaul.mn.us
Mon Jun 14 13:51:07 EDT 2010
Brent,
Well you did specify NO Mapscript in the first message. I tend to shy away from Mapscript myself as well.
Your description of things are seeming to point at an administrative interface of sorts, which I've been pondering for a while now (Years!), where the abstract things like visible layers, and desired cartography was moved to the user realm, right in line with your Online GIS . . .
bobb
>>> Brent Fraser <bfraser at geoanalytic.com> wrote:
Bob,
Yes that's possible; and so is using Mapscript. My hope was that I (and
others wanting to do bound styling) could generate a legend with a minimum of
scripting/coding/querying. Personally, I think bound styling could be very
powerful, especially when combined with a user login, a web page to
"create/define" layers and classes, and the GeoMOOSE/OpenLayers ability to
digitize features (what's next? a web-based GIS, oh nooo...)
Brent
Bob Basques wrote:
> Brent,
> Ok, this is sort of way out there, I read your Legend Mail (MSG10603)
> and wondered about . . .
> What if you use MapServer with a template, to build a Mapfile on the fly
> from the database query, then pass that in to MapServer for legend
> rendering? Seems like the long way round, but might prove an
> interesting experiment to work out a permanent solution.
> Also, wasn't there work recently related to passing in a Mapfile via
> CGI? Maybe there is a possibilty of piping these operations together
> somehow, just thinking out loud here.
> bobb
> Yewondwossen Assefa wrote:
>> On 11/06/2010 11:54 AM, Lime, Steve D (DNR) wrote:
>> > I think it would be a reasonable addition. Are you thinking about
>> > simply adding a visibility flag to a layer and flipping it
>> > if features are rendered? Often legend rendering is done separately
>> > from drawing, as two separate requests. Presumably you'd
>> > need a something like a fake draw map option in the legend code to
>> > make a drawing-like pass through the data. Could get expensive.
>> Yes, it could be an expensive operation to do a fake draw to get the
>> legend. I am wondering if we could save something when a draw is done
>> and retrieve it for the legend if it validates the current
>> layers/extent constraint. Draw and legend are separate process but
>> come usually one after the other so trying to take into account that
>> fact might help.
>> regards
> And it could solve my problem of generating a legend when using bound
> styling
> (http://www.mail-archive.com/mapserver-users@lists.osgeo.org/msg10603.html)
> Best Regards,
> Brent Fraser
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20100614/84c7c76a/attachment.html
