[mapserver-dev] Label Angle Auto Issue (Trac #1688)
Chris Hodgson
chodgson at refractions.net
Tue Mar 2 20:53:36 EST 2010
Hi Devs,
The issue is Trac #1688 [1] - it's kinda long, so in summary: we want a
way to be able to force labels to be drawn upside down, based on the
angle of the line. The existing "ANGLE AUTO" function is "smart" and
always tries to render them right-side up, but in our client's case the
line segments have been specifically made to define the location of
individual characters for labeling actual map features, and if the
segment goes from right-to-left it intends for the character to be
rendered upside down (manually defining the placement of characters for
a result that looks something like "ANGLE FOLLOW").
I believe this issue has been hanging around (for 4 years) because
no-one has tried hard enough force a consensus on how to implement the
configuration of this feature - that's why I'm bringing it out of Trac
and onto the dev list, my apologies if this is not appropriate.
Dan suggested the following a couple years back:
Here is an idea: instead of adding a new autoanglealgorithm member in
the labelObj as was proposed in the auto2.tar.gz patch, we could get rid
of autoangle and autofollow and combine all of them into a single
label->anglemode member with the following possible values:
- 0, the default means that the angle value is either static or bound to
an attribute
- MS_AUTO
- MS_AUTO2 (the new algorithm)
- MS_FOLLOW
Steve, do you expect any problem with that approach? I can take this
ticket if you want, just reassign to me.
Steve replied with:
Dan, I think that would work. MapScript would be simplified
($label->anglemode = ...) and I assume we'd keep the mapfile syntax the
same (e.g. ANGLE AUTO2). We could allow explictly setting the anglemode
in the mapfile as well with the idea of depricating ANGLE AUTO sometime
in the distant future if necessary.
But no-one ever got around to implementing this. More recently Alan
picked up it for a look, but it doesn't look like he's taken it anywhere
yet. Our client, GeoBC, would really like to see this get into the next
release, seems like we should be able to slide it into the 6.0 schedule?
So I'd like to confirm that Dan's earlier proposed method is still an
acceptable solution, and then go ahead and implement it and submit a
patch. I'd also appreciate any guidance or warnings about gotchas that I
might encounter with this approach.
Thanks,
Chris
[1] http://trac.osgeo.org/mapserver/ticket/1688
