[mapserver-dev] The legendary story of mapObj.zoomRectangle (a
cabaret show)
Alan Boudreault
aboudreault at mapgears.com
Wed Mar 3 16:46:36 EST 2010
Tamas,
Someone also reported on IRC that problem (IIRC, 2-3 weeks ago). My change was
a misinterpretation and shouldn't have been done. I had not understood why
this part of the code was different of the php similar function. As you said
on IRC "treating maxy >= miny as a failure is semantically irregular", but
this commit changed the behavior of the function that exists for a long time.
I would suggest to revert it and backport it in branch 5.6.
Perhaps it would be a good opportunity to release 5.6.2 ? Are there enough
important fixes in the branch?
regards,
Alan
On March 3, 2010 03:49:54 pm Tamas Szekeres wrote:
> Folks,
> Upon upgrading my existing application to 5.6.1 I'm getting frustrated
> about the changes of the rectangle check in mapObj.zoomRectangle. So let
> me summarize how the related code have changed within the past 5 years.
> - 2004-06-26 The stuff has been committed by sean in r3294 mapzoom.i Ln 280
> if (poPixRect->maxy >= poPixRect->miny)
> msSetError(MS_MISCERR, "Georeferenced coordinates miny <=
> maxy", "mapscript::mapObj::zoomRectangle()");
> return MS_FAILURE;
> - 2006-05-30 First attempt to swap miny and maxy by umberto in r5472
> - 2006-07-24 The change have been reverted by hobu in r5542
> - 2006-12-13 Second attempt to swap miny and maxy by sdlime in r5859
> - 2006-12-13 Reverted the change by sdlime in r5864
> - 2009-10-12 Third attempt to swap miny and maxy by aboudreault in r9444
> There have been a couple of tickets related to this issue like:
> http://trac.osgeo.org/mapserver/ticket/1817
> http://trac.osgeo.org/mapserver/ticket/1982
> http://trac.osgeo.org/mapserver/ticket/1988
> http://trac.osgeo.org/mapserver/ticket/3286
> While I'm a bit lost with the reason of these reverts it seems we don't
> have solid standpoint on how this consistency check should be done. I
> would anticipate I'm not against this change, however I would not want to
> alter my existing scipts (like now) in every release in order to have my
> code working.
> Could someone confirm this change won't be reverted in the future releases?
> Best regards,
> Tamas
Alan Boudreault
Mapgears
http://www.mapgears.com
