[mapserver-dev] Using mapserver with non-projected raster files
Jim Klassen klassen.js at gmail.com
Mon Mar 8 15:41:31 EST 2010
On Mar 8, 2010, at 11:15 AM, Frank Warmerdam <warmerdam at pobox.com>
wrote:
> Jan Hartmann wrote:
>> Hi all,
>> I've been using MapServer for a long time to display raw raster
>> files without projection information, to get control points for
>> georeferencing. Up to MS 4.10.5, this was no problem, but with
>> 5.6.0 mapserv hangs: no error, the application just doesn't finish.
>> Is this a bug or is MapServer meant to work with projected files
>> only nowadays? If so, there should be an error message, but I would
>> prefer the old behavior
> Jan,
> It is not intentional that MapServer not work with ungeoreferenced
> rasters.
> If you could construct a small simple demonstration of the issue and
> file
> a ticket assigned to me I'll dig into it.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for
> Rent
This may not be your problem, but
If you are using a "PROCESSING RESAMPLE=" option then a raster w/o a
geotransform will be a problem. (I found this was occuring in certain
WMS cases.)
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
