[mapserver-dev] WFS + GEOS + native Oracle Spatial + <ogc:Intersects> = not working?
Yewondwossen Assefa yassefa at dmsolutions.ca
Fri Mar 12 08:02:15 EST 2010
Hi There,
 I believe this has been addressed in
http://trac.osgeo.org/mapserver/ticket/3305. The patches are available
in the 5.6 branch in svn and should be available for 5.6.2 release. If
possible can you try building against the svn version.  Quick test I did
with a filter that uses intersect and bbox return expected results:
....<Filter><Or><Intersect><PropertyName>Geometry</PropertyName><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>124222,479955
132851,479955 132851,483688
124222,483688</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersect><BBOX><PropertyName>geometry</PropertyName><Envelope
srsName='EPSG:28992'><lowerCorner>247268
602563</lowerCorner><upperCorner>252296
608479</upperCorner></Envelope></BBOX></Or></Filter>....
regards,
Vitali Diatchkov wrote:
> Hello.
> I have several issues about MapServer as a WFS service.
> I am using MapServer as a WFS service from UDIG.
> Recently I have found that  raw <ogc:Intersects>  filter doesn't work
> on latest MapServer that I compile myself against layer with native
> Oracle Spatial connection. The reason was absence of GEOS support, so
> I complied MapServer with GEOS. And things became even more unexpected.
> First of all after switching debug tracing in MAP file I have found
> that the log file contains:
> [Thu Mar 11 22:03:29 2010].859000
> msOracleSpatialLayerResultGetShape(): OracleSpatial error.
> msOracleSpatialLayerResultGetShape record out of range
> The next step was debugging from Visual Studio and what a surprise.
> Well it seems native Oracle  Spatial connector can directly deal only
> with WINDOW-based queries (or BBOX). All spatial filters like
> <ogc:Intersects> are processed in GEOS. But this is implemented in
> context of legacy architecture and I wouldn't be the first to mention
> that is is not efficient at all.
> What I have found that if Intersects filter provided (as an example of
> non BBOX filter) then during first iteration all records are extracted
> from the table in  msOracleSpatialLayerWhichShapes function. At the
> same time an extent of the whole layer is used to get those records.
> If there are 1000000 records, means all are loaded. Intersection is
> done then using GEOS spatial predicates with a geometry provided in
> filter for all loaded records. Resuts are somehow cached.
> Then the next step starts in FLTLayerApplyPlainFilterToLayer calling
> FLTAddToLayerResultCache. And there a bug is in: a) architecture b)
> "maporaclespatial.c" logic.
> Let's assume there are 1300 records in Oracle table. The buffer in
> msOracleSpatialStatement structure is 1024 by default.  When last
> element in buffer is processed then the next bunch of items are
> fetched from a result set. In our case first time buffer is fully
> loaded and has 1024 items. In next fetching the rest 276 items are
> loaded into the buffer starting from 1st cell. Fetching I am talking
> about takes place in msOracleSpatialLayerNextShape function.
> What information is cached?
> addResult(lp->resultcache, shape.classindex, shape.index,
> shape.tileindex);
> in msQueryByOperator function.
> In my test case shape.index is a primary key of a feature from a
> database, like "214789" and shape.tileindex is a kind of index of the
> cell in a buffer "msOracleSpatialStatemen.obj".  Let's assume 5
> features are actually in a result of intersction operation. In current
> logic their shape.tileindex value might be 45, 567 or 1238 e.g. that
> is out of mentioned buffer limits. Actually is is assigned in
> shape->tileindex = sthand->row_num; /* Index into cursor */
> where row_num just grows permanently.
> FLTAddToLayerResultCache leads to a call of
> int msOracleSpatialLayerResultGetShape( layerObj *layer, shapeObj
> *shape, int record, long pkey )
> where arguments are sort of:
> record=-1 (always)
> pkey=214789
> where "record" is equal to -1 (always, comes from  "status =
> msLayerResultsGetShape(psLayer, &shape, -1, anValues[i]);")
> this -1 actually kills all the logic in
> msOracleSpatialLayerResultGetShape.
> In a result we have nothing to return as a WFS response and dummy XML
> is output:
> <wfs:FeatureCollection xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd" >
> <gml:boundedBy>
> <gml:Box srsName="EPSG:2393">
> <gml:coordinates>-1.000000,-1.000000
> -1.000000,-1.000000</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> </wfs:FeatureCollection>
> After some studying of code in maporaclespatial.c I can not understand
> how this scenario might work at all. Is it so that WFS with GEOS and
> MapServer's native Oracle Spatial is not a solution for this use case
> and only simple BBOX queries works?
> But even if to imagine that Intersects filter works and there is no
> problem with buffer and ietms indexing overlapping, loading of all
> records during first step for processing by GEOS is not appropriate also.
> The codebase of MapServer is large and I could miss something
> important.. Any comments on that?
> Regards,
> Vitali Diatchkov.
> P.S. Latest branch-5-6 codebase is used.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
