[mapserver-dev] Transparent map with non-transparent legend
strk strk at keybit.net
Tue Mar 16 07:22:31 EDT 2010
Hi all,
I've been struggling for some time trying to get
a legend background color filled and finally sorted
into looking at the code.
I've found that IF the OUTPUTFORMAT (map-level) is set
to use transparency then the legend background won't
be set, due to msImageInitAGG checking OUTPUTFORMAT
before honouring the passed background.
If I understood correctly previous mapserver versions
allowed a TRANSPARENT setting for different objects
(layer/legend) but this is being deprecated.
Is there a way nowadays to get non-traspanrent-background
legend embedded into a transparent-background map ?
Thanks in advance.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
