[mapserver-dev] Re: MapFile generator?
Tamas Szekeres szekerest at gmail.com
Sat Mar 20 05:55:30 EDT 2010
2010/3/19 Mulone <mulone at rome.com>
> In relation to mapscript, would it be possible/interesting to isolate the
> classes dealing with the mapfile leaving all the trick bindings out?
> I mean, in the end what a lot of developers need is a simple tree to handle
> and generate valid mapfiles, without messing with other things. I'm finding
> the java binding quite tricky to integrate because I'm working on a
> framework (Grails) and I don't know how to make the DLL work in my set up.
Mulone,
I don't exactly understand, what you mean. The mapscript functions are
invoking the functions exposed by those dll-s (including mapscript.dll,
libmap.dll, proj.dll and many more), therefore having those dll-s installed
is required for the interface to operate.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20100320/b5e19e6e/attachment.html
