[mapserver-dev] Release of 5.6.3 today
Daniel Morissette dmorissette at mapgears.com
Mon Mar 22 09:51:26 EDT 2010
Hi Dev's,
As you may have seen in my message from yesterday, an issue has been
found with PostGIS layers in 5.6.2 which is now fixed as far as I can tell:
   http://trac.osgeo.org/mapserver/ticket/3324
Since this issue will block most uses of postgis data in 5.6.2, I plan
on releasing 5.6.3 at the end of the day today unless I hear objections
(before 5.6.2 starts to spread around too much).
I'd invite you all to please test the current SVN branch-5-6 in your
respective environments before the end of the day today and report here
if you come across any issue.
Thanks
Daniel
Daniel Morissette
http://www.mapgears.com/
