[mapserver-dev] REST config API
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Mar 31 16:40:14 EDT 2010
Bart,
I think this is a very interesting idea. I'm not even sure how much if
any changes are required in mapserver. I only skimmed the doc link
below, but it seems that this could be totally done as an add-on server
sitting beside mapserver and that mapserver would only need access to
the mapfiles created and managed by the REST service.
-Steve W
Bart van den Eijnden wrote:
> Hi Brent,
> see:
> http://docs.geoserver.org/stable/en/user/extensions/rest/index.html
> It's a REST interface to create configuration on the fly, so styles,
> datastores, layers etc.
> Best regards, Bart
> On Mar 31, 2010, at 7:05 PM, Brent Fraser wrote:
>> Bart,
>> I'm not familiar with Geoserver's REST interface, but making
>> somewhat Mapserver configurable on-the-fly (or at least making the
>> default behavior more implementor-friendly) is something I'm
>> interested in.
>> My problem is not with the mapserver-client interaction (which is
>> what REST defines, I think), but with the mapserver-datasource
>> interaction, but they could be related.
>> As an implementor why do I need to specify the CLASSes (if I'm
>> getting symbology/styling from database attributes)? Why do I
>> need to specify the TEMPLATE to get any attributes values from a
>> query?
>> And here's a question for developers: What is the minimum set of
>> required entries in a MAP file to render a map graphic (e.g. from a
>> shape file)? Now, why are those entries required? Is it possible
>> for mapserver to create reasonable defaults from the datasource?
>> Best regards, Brent Fraser
>>> Hi list, are there any plans to support something similar to
>>> Geoserver's REST interface to create configuration on the fly?
>>> IMHO this would be a very interesting (and currently missing)
>>> feature for Mapserver. Also, client configuration tools could
>>> publish to both Mapserver and Geoserver using a common interface.
>>> Best regards,
>>> Bart_______________________________________________ mapserver-dev
>>> mailing list mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> _______________________________________________ mapserver-dev mailing
