Hi list, when a very small BBOX filter is sent to Mapserver WFS, and the source layer is a point layer, it is very hard to actually select the point, normally no result is given. Does Mapserver use TOLERANCE in this particular case? I can't seem to influence the situation by increasing TOLERANCE. Using MS 5.4. TIA. Best regards, Bart
