[mapserver-dev] msOracleSpatialLayerWhichShapes(): OracleSpatial error
Agostino acsviluppo at yahoo.it
Thu May 13 19:42:29 EDT 2010
I'm using mapscript c# (mapserver 5.6.3)
I want to highlight an element in my map and this is what i write
layerObj lo = map.getLayer(i);
lo.queryByAttributes(map, null, strQuery, mapscript.MS_MULTIPLE);
map.drawQuery();  <--- The map image is generated with the highlighted
element.
After i want to to clear my query and my code is:
map.freeQuery(-1);
map.drawQuery();  <--- throw error
msOracleSpatialLayerWhichShapes(): OracleSpatial error. Error: ORA-00600:
codice di errore interno, argomenti: [17182], [0x2581CE802], [], [], [], [],
 . Query statement: SELECT ID, GEOMETRY FROM AAAMAMCOMU WHERE SDO_FILTER(
GEOMETRY, MDSYS.SDO_GEOMETRY(2003, :srid,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),:ordinates ),'querytype=window') =
'TRUE' . Check your data statement.
[Thu May 13 18:52:46 2010].621000 msDrawMap(): Image handling error. Failed
to draw layer named 'Limiti Comunali'.
With mapserver 5.4 my code is ok.
Thank you
Agostino.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/msOracleSpatialLayerWhichShapes-OracleSpatial-error-tp5048864p5048864.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
