[mapserver-dev] Proposing some homepage changes...
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue May 25 09:00:06 EDT 2010
I'm also +1 for installing sphinx 1.0-dev
-jeff
Lime, Steve D (DNR) wrote:
> +1 on installing the unreleased code.
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Howard Butler
> Sent: Monday, May 24, 2010 8:35 AM
> To: MapServer Dev Mailing List
> Subject: Re: [mapserver-dev] Proposing some homepage changes...
> As I chatted with Jeff on IRC the other day, this is quite easy to do with the unreleased Sphinx 1.0 trunk (See an example that I did for libLAS at http://test.liblas.org . The question is whether or not we want to wait until 1.0 is actually released, or install the unreleased code (it's been quite stable for me for quite a while and I know that MapServer's site builds just fine with it) on mapserver.org (and geotools.org too).
> Georg hasn't yet stated when the 1.0 release date for Sphinx will be, and he usually releases things "when they're ready", so it might be a bit.
> Howard
> On May 7, 2010, at 10:51 AM, Daniel Morissette wrote:
>> Hi Steve, Jeff,
>> I just wanted to add that I like the changes you are suggesting and are working on.
>> Thanks
>> Daniel
>> Jeff McKenna wrote:
>>> Hi Steve,
>>> I fully agree with you.
>>> I made some minor changes so that the announcement sections no longer appear in the TOC: http://www.mapserver.org/
>>> I also made an attempt to clean up the left sidebar nav, with the sections that you suggested, through our Sphinx layout template: http://www.mapserver.org/trunk/en/index.html
>>> Impressions/comments?
>>> Personally, I like it better. What I don't like is the "Table of Contents" section that still remains on that index page - oh I tried to remove it, searching the Sphinx Google group, trying many different ways, but in the end I failed to remove it. It only appears on some pages though.
>>> It's a start?
>>> -jeff
>>>> Hi all: I'd like to propose some changes to the mapserver.org homepage. Wondering how feasible they'll be via Sphinx:
>>>> - Breadcrumb. Really should start at "Home" and then go from there, e.g.:
>>>> Home >> Documentation >> MapScript or
>>>> Home >> FAQ
>>>> Home >> Develelopment >> RFCs
>>>> - TOC on the homepage shouldn't be announcements but rather something like:
>>>> Community
>>>> Mailing Lists
>>>> IRC
>>>> Wiki
>>>> Development Documentation
>>>> Introduction
>>>> FAQ
>>>> Mapfiles
>>>> MapScript
>>>> Downloads
>>>> Issue Tracker
>>>> - Announcements could continue below the fold on the main part of the homepage
>>>> It's not user friendly as is. The shorter, more meaningful TOC would also help to pull the OSGEO and FOSS4G icons up the page. Thoughts?
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> Daniel Morissette
>> http://www.mapgears.com/
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
