[mapserver-dev] epub docs...
Howard Butler
hobu.inc at gmail.com
Wed May 26 12:28:46 EDT 2010
John,
Now that we have upgraded to Sphinx 1.0, (english-only) epub is now available. For some reason, the build throws unicode errors on the german build, but I suspect that is due to our old python on mapserver.org
http://mapserver.org/MapServer.epub
Enjoy on your ipad!
Howard
On Apr 26, 2010, at 8:49 AM, Howard Butler wrote:
> On Apr 26, 2010, at 8:28 AM, John Cole wrote:
>> I see where Howard added an epub step to the documentation creation… is that available for download anywhere?
> Not yet. You need an unreleased Sphinx 1.0 to be able to create epub docs, and the server where we run docs nightly doesn't have that yet. I hope to enable things soon once after 1.0 is released.
> If you're adventurous, you can pull down a copy of the latest Mercurial repository and issue 'make epub' and things should work. I was able to get a usable set in my initial test.
> I will also note that I have been working with the rst2pdf developer to ensure that the MapServer docs build with that tool as well. That Sphinx extension will allow us to build a styleable (and better looking in my opinion) PDF without the latex overhead. MapServer's complex and large docs have been a good test case(s) of the software ...
> Howard
