[mapserver-dev] Rendering issues (cairo and others)
thomas bonfort thomas.bonfort at gmail.com
Tue Nov 9 02:55:24 EST 2010
On Sat, Nov 6, 2010 at 23:16, Tamas Szekeres <szekerest at gmail.com> wrote:
> Folks,
> I wanted to prepare my daily built binaries with cairo rendering support on
> Windows. In this regard the following dependencies have been compiled.
> pixman-0.20.0 (with no MMX and SSE2 support at this stage)
> cairo-1.10.0 with the following features:
> CAIRO_HAS_WIN32_SURFACE 1
> CAIRO_HAS_WIN32_FONT 1
> CAIRO_HAS_PNG_FUNCTIONS 1   --> with libpng 1.2.35
> CAIRO_HAS_FT_FONT 1                   --> with freetype 2.3.9
> CAIRO_HAS_FC_FONT 1                  --> with fontconfig 2.6.0
> CAIRO_HAS_PS_SURFACE 1          -->zlib 1.2.3
> CAIRO_HAS_PDF_SURFACE 1
> CAIRO_HAS_SVG_SURFACE 1
> CAIRO_HAS_IMAGE_SURFACE 1
> CAIRO_HAS_RECORDING_SURFACE 1
> CAIRO_HAS_USER_FONT 1
> CAIRO_HAS_INTERPRETER 1
> Having the configuration above with mapserver-trunk, I always get a blank
> image with no features drawn on it regardless of the layer type.
> Do you have any idea what could be wrong with this or what else should be
> tested to identify the problem?
> Further questions/problems:
> 1. Would it be reasonable to include support for the cairo Win32 surface in
> Mapserver?
What is there to gain from using a win32 surface? (the question also
stands for the xlib backend provided by cairo).
I don't think it would be too complicated to add, probably just a
question of adding an outputformat definition and a couple of support
functions in mapcairo.c
> 2. I can see much of unimplemented functions with many of the vtable
> renderers (like GD2) do we have a plan to add a reasonable implementation
> here? There is quite some progress with this in sandbox/mapserver6, however
> this version doesn't seem to compile on Windows at the moment. I also see
> some additional dependency to giflib which should also be made conditional
> in the build process.
All of the work is in the mapserver6 sandbox for now. Can you give
more information as to what doesn't compile, so I can move forward and
merge it back into trunk. And yes, there's now a dependency on giflib
for loading pixmaps, and libpng and libjpeg for pixmap loading and
image saving
> 3. I've also added a new vtable method in r10698 in order to support the
> renderer specific way to serialize the images. Actually I'm not too
> satisfied with the signature of saveImage which if pretty much predefined to
> save on a FILE handle, it would be much more handy to save on a 'stream
> context structure' which could eventually be based on a file handle, a
> memory buffer, stdout, whatever, something like we do with msIOContext
> actually. For example with the GD driver, I would be in favour of
> transferring the the gdIOCtx way of serializing the image to a stream
> (msSaveImageGDCtx) which have been used for either the file based or the
> memory based output recently.
saveImage with a FILE handle is the only function used by the
non-mapscript code in mapserver. For the mapscript functions there's
msSaveImageBuffer, which is also implemented for the plugin backends
(http://trac.osgeo.org/mapserver/browser/sandbox/mapserver6/maputil.c#L747).
The actual saving is already abstracted to be able to write to a
buffer or a stream
(http://trac.osgeo.org/mapserver/browser/sandbox/mapserver6/mapimageio.c#L801)
although this might be refactored a bit to use an msIOContext.
Where you thinking of something other than this?
> The long and the short of it is, I think the new rendering approach is in a
> good shape to fininsh up this phase and finalize a set of the features being
> ready for the 6.0 release.  I'm confidently looking forward to have the
> users start testing with these new features as soon as possible.
I'll wait for your feedback from the compilation on win32 of the
mapserver6 and merge back into trunk.
> Best regards,
Thanks for the feedback,
Thomas
> Tamas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
