[mapserver-dev] Ticket 3559 - malloc/calloc/realloc return values should always be checked
Alan Boudreault
aboudreault at mapgears.com
Wed Nov 17 14:30:25 EST 2010
Yes, I'll take care to create a wiki page after the work.
Alan
On November 17, 2010 02:24:03 pm Lime, Steve D (DNR) wrote:
> I guess I favor the explicit names (should msStrdup be msSmallStrdup?),
> less confusion. If I saw msMalloc() I would assume it's equivalent to
> malloc() in terms of use (like msFree/free) and that's not the intention.
> I don't think there's a need for a vote. The discussion has been out in
> the open and others have had the chance to weigh in. It would be nice to
> see this documented in the context of do's and don'ts related to the
> cleanup work Alan did. We don't want to go and reintroduce the vary code
> he worked so hard to clean up. Perhaps a wiki page?
> Steve
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Daniel
> Morissette Sent: Tuesday, November 16, 2010 2:46 PM
> To: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] Ticket 3559 - malloc/calloc/realloc return
> Reviving an old thread... it seems that several people were in support
> of this option, but some were concerned about the proliferation of
> exit() and the side-effects that they could create in some non-CGI
> environments. While I would agree that spawn-fcgi is flawed if it cannot
> restart aborted processes, especially in cases where a process is
> running out of memory, I also believe that we could try to be more
> exit-friendly in some non-fatal situations and this can be discussed
> further in the context of ticket #3099.
> So for the short term, it would seem to make sense to introduce the use
> of msSmallMalloc(), msSmallCalloc() and msStrdup() which would exit() on
> out of memory after attempting to report the error through stderr, since
> there is not much we can do anyway when we're out of memory.
> With respect to better handling of exit() in other situations, let's
> save that for another thread.
> Do we need a PSC vote before we go ahead with msSmallMalloc(),
> msSmallCalloc() and msStrdup()?
> What about using the names msMalloc() and msCalloc() instead and
> properly documenting that they are intended for use with small
> allocations only (as is done for GDAL's CPLMalloc family of functions)?
> Daniel
> Frank Warmerdam wrote:
> > strk wrote:
> >> On: Thursday, October 07, 2010 9:42 AM, Frank Warmerdam wrote:
> >>> I would like to propose an msSmallAlloc() function that behaves in a
> >>> similar
> >>> fashion, just writing an error to stderr in case of failure and calling
> >>> exit(). Likewise, an msStrdup() with similar behavior.
> >> Better than nothing, but this will fail to be catchable by mapscript
> >> or the CGI (think XML or in-image exception).
> >> It's very frustrating when you get a blank image and have
> >> to resort to forcing text/html content type or even worst
> >> reading server logs, and there are already lots of such cases.
> > Strk,
> > Well, I can assure you that in the situation where msSmallAlloc()
> > fails there would be no way of actually preparing an error report
> > and burning it into an image for "inimage" error reports. Things
> > are already too desperate.
> > It is in fact very doubtful that we could even allocate a new
> > errorObj for the error stack if we called msSetError().
> > To put all this in context, GDAL/OGR has always "just died" with an
> > error message to stderr if small allocations fail, including when run
> > in the context of applications like ArcGIS. This has never yet, as
> > far as I recall, been reported as a problem.
> > Best regards,
Alan Boudreault
Mapgears
http://www.mapgears.com
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20101117/345e9398/attachment.html
