[mapserver-dev] renderer api committed
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Fri Nov 19 15:54:35 EST 2010
Note that I added a "Renderer API" component in trac just now. I figure that will be the easiest way
to group tickets related to this new functionality.
Steve
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of thomas bonfort
Sent: Friday, November 19, 2010 11:07 AM
To: MapServer Dev Mailing List
Subject: [mapserver-dev] renderer api committed
Hi all,
I've (finally) committed the mapserver6 sandbox back into trunk. the
msautotest suite indicates a consequent number of failed tests, but
most of them are due to some subtle rendering differences.
Of notable importance when using this:
* compilation requires libpng, libjpeg and gif headers. the gif
configure script is a bit awkward for now, you have to use
--with-gif=/usr even if gif_lib.h is in the default INCLUDE path
* GD renderer only supports PC256 mode. if your outputformats use RGB
or RGBA modes, you'll get switched to AGG.
* using symbols as brushes along a line is not (yet) supported
* PDF, SVG is rendered through cairo
* SWF is not implemented, and should not be enabled (it won't compile)
* opengl backend can be enabled
I'm nearly certain that this change will break some things, especially
if you've been using more or less documented hacks for fine tuning
symbology, so please excuse me in advance for that and report back so
we can iron things out until the release.
best regards,
thomas
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
