[mapserver-dev] fontconfig patch
thomas bonfort
thomas.bonfort at gmail.com
Sat Nov 27 07:47:33 EST 2010
guys,
is there any reason why mapserver isn't using fontconfig to lookup
fonts that aren't configured in the fontset?
I've got a patch of a dozen lines that seems to be working ok and
shouldn't affect backwards compatibility, and was wondering if anyone
would have reasons to oppose to its inclusion before I start
integrating it cleanly.
what it basically does:
when looking up a font by name, we first query the supplied fontset
for the path to the font.
* if the fontset contains that font, then we proceed as usual.
* if not, we do a fontconfig lookup for the given font name, and
insert the found font into our fontset (to avoid calling fontconfig
over and over again for the next labels)
pros:
* no need to define and populate a fontset.
* we get access to a "default" truetype font, making mapserver run out
of the box without having to supply a ttf font file.
cons:
* extra dependency, although the feature will be disablable at compile
time, and the dependency already exists (though probably without the
need for header files) through gd and cairo.
* some extra steps for cleaning up some fontconfig structures at exit
* the first time the fontconfig functions are called and there is no
fontconfig cache on the system, the processing time can be *very* long
while waiting for fontconfig to create its cache. This is a one time
operation though, although I should investigate what happens in the
case an unpriviliedged user is running the command.
* the ouptut of a mapfile can be different depending on the systems it
runs on, as fontconfig may return a different font depending on what
fonts are installed on the system.
To me this seems like a nice usability enhancement for mapserver, but
I won't be offended if we decide we don't want this added.
best regards,
thomas
Index: maplabel.c
--- maplabel.c (revision 10758)
+++ maplabel.c (working copy)
@@ -35,7 +35,7 @@
#include <gdfontt.h>
#include <gdfontmb.h>
#include <gdfontg.h>
+#include <fontconfig/fontconfig.h>
#include "mapserver.h"
MS_CVSID("$Id$")
@@ -760,17 +760,35 @@
char *msFontsetLookupFont(fontSetObj *fontset, char *fontKey) {
- char *font;
- if(!fontKey) {
- msSetError(MS_TTFERR, "Requested font (NULL) not found.",
"msFontsetLookupFont()");
- return NULL;
- font = msLookupHashTable(&(fontset->fonts), fontKey);
- if(!font) {
- msSetError(MS_TTFERR, "Requested font (%s) not found.",
"msGetLabelSize()", fontKey);
- return NULL;
- return font;
+ char *font = NULL;
+ if(!fontKey) {
+ msSetError(MS_TTFERR, "Requested font (NULL) not found.",
+ return NULL;
+ if(!fontset) {
+ msSetError(MS_TTFERR, "fontset is NULL", "msFontsetLookupFont()");
+ return NULL;
+ font = msLookupHashTable(&(fontset->fonts), fontKey);
+ if(!font) {
+ FcPattern* pattern = FcNameParse ((FcChar8 *) fontKey);
+ FcResult fcresult;
+ FcConfigSubstitute (0, pattern, FcMatchPattern);
+ FcDefaultSubstitute (pattern);
+ FcPattern *matched = FcFontMatch (0, pattern, &fcresult);
+ if (FcPatternGetString (matched, FC_FILE, 0, (FcChar8**)&font) !=
FcResultMatch) {
+ font = NULL;
+ msSetError(MS_TTFERR, "Requested font (%s) not found.",
+ } else {
+ struct hashObj *entry =
msInsertHashTable(&(fontset->fonts),fontKey,font);
+ //free(font); TODO this segfaults, check who allocated the string.
+ font = entry->data;
+ FcPatternDestroy(pattern);
+ return font;
