[mapserver-dev] Ticket 3537 - Buffer overflow vulnerabilities
Yewondwossen Assefa yassefa at dmsolutions.ca
Wed Oct 6 13:57:41 EDT 2010
  Except the 2 issues I mentioned, It build ok for me.
> Building with MSVC (9), I get build errors for the following declaration:
> size_t buffer_size = 512;
>  char buffer[buffer_size];  #line 2209
> mappostgis.c(2209) : error C2057: expected constant expression
> mappostgis.c(2209) : error C2466: cannot allocate an array of constant
> size 0
> mappostgis.c(2209) : error C2133: 'buffer' : unknown size
>  I will change locally and continue the build.
> I also get build errors usually when variables are declared in the
> middle of the code and not at the beginning of functions or beginning
> of loops. I am not sure if it is a setting that I need to do or It is
> is simply not valid for all compilers. I tend to correct that when I
> build on windows.
> regards,
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
