[mapserver-dev] WFS GetFeature - gml_constants, et al
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Oct 7 09:29:56 EDT 2010
Hi Steve,
I am updating the WFS Server doc now, I'll check on this gml_contants
issue (a ticket though might help).
-jeff
On 10-10-06 6:46 PM, Lime, Steve D (DNR) wrote:
> Hi Frank: Glad you had some success. The gml_constants feature was added explicitly for some WFS application schema work done for the FGDC. We produced a how-to that detailed those options. Will have to look for it...
> http://maps.dnr.state.mn.us/mapserver_docs/wfs_tutorial/index.html
> Looks like it's not there either. I'll create a ticket on that. I don't see that as something you should support. The constants are really only relevant in the application schema context. I concur with your support of the other GML metadata config options. Out of curiosity, does the KML driver also use those? Did it implement others that might make sense for OGR?
> Steve
> ________________________________________
> From: mapserver-dev-bounces at lists.osgeo.org [mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam [warmerdam at pobox.com]
> Sent: Wednesday, October 06, 2010 2:23 PM
> To: mapserver-dev
> Subject: [mapserver-dev] WFS GetFeature - gml_constants, et al
> Steve,
> I have had some success with having WFS GetFeature use the template
> engine for output.
> Now I'm working on OGR output and I'm wondering how much of the
> existing WFS gml output logic I need to replicate. For instance there
> is a concept of "gml_constants" - apparently for adding constant fields
> in returned features. I can't find any documentation on this other than:
> http://www.mail-archive.com/mapserver-users@lists.umn.edu/msg12376.html
> http://trac.osgeo.org/mapserver/changeset/4936
> Were you intending to document this in the WFS Server document? Should
> I try to replicate the behavior for the non-GML output?
> I'm guessing that the gml_groups support doesn't really make sense in
> non-GML products - would you agree?
> I am guessing we *do* want to replicate gml_include_items, gml_[item]_alias,
> and gml_[item]_type behavior in non-GML feature output. Would you agree?
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
