[mapserver-dev] Ticket 3559 - malloc/calloc/realloc return values should always be checked
Thu Oct 7 11:19:45 EDT 2010
Pierre Mauduit wrote:
> in a FastCGI setup, your process is not even supposed to exit()
Pierre,
I would note that this is only true for fastcgi processors that are
incapable of restarting fastcgi subprocesses that die.  This is not
a problem with the widely used apache+mod_fastcgi.
I do *not* consider fastcgi a situation where an exit() is a particularly
bad way of dying when you have to die.
Best regards,
